Since Larry's thread came up I thought some of us might need a refresher. This deals with water (mostly) but any liquid is not very compressable so the theory is similar. Question though, wouldn't turning over the motor with the kill switch in the off position prevent hydrolock and engine damage? Even if the cylinder was full of liquid, there would be no fire to ignite it. Comments?
http://en.wikipedia.org/wiki/Hydrolock
Hydrolock
- CBXRoger
I've been told by more than one knowledgeable CBX mechanic that the starter motor alone doesn't have the power to do any serious damage and that bent rods and the like are the result of one or more cylinders firing before the wet cylinder comes to TDC on the compression stroke
Based on this, if there's any question at all (like when I put it on the sidestand and forget to turn off the fuel) I do just as you suggested Terry and turn off the kill switch before attempting to start it
- alimey4u2
- ICOA Web Video Director
OK not a real test as my rods are OMT but I have had # 1 hydrolock just turning the starter motor ( ignition off) without any measured effect. Popped the plugs, measured the stroke with a DTI on an extension & no difference in piston height at TDC...
I then pulled all the plugs & ran the motor on the starter to clear, squirted oil through the plugholes. Span it again & replaced the plugs... Changed oil & filter..Good to go...
- FalldownPhil
Speaking from personal experience. Don#6141 is correct. The starter motor alone with no fire will not bend a rod. I had this experience a few years ago. If ever there is any question about the possibility of a cylinder with fuel in it I will crank the engine with the switch in the off position. I did this on a suspect system and had the engine stop dead in its tracks. I am sure that if the switch had been in the run position, it would have fired on another cylinder and bent a rod. Instead, I pulled the plugs and cranked it around a few times. All is well that ends well.
Very Best,
Very Best,
- alimey4u2
