clutch cable
- cbxtacy
clutch cable
I'm so good. Your typical hard working, good looking, intelligent and MODEST CBX owner. My high mileage, mostly stock with sport kit 82 clutch cable was going. I left the tank and seat on, dis-connected both ends of the cable, taped the bar end of the new one to the engine end of the bad one, and pushed and pulled it through. Piece of cake. Remember this the next time you have to replace a clutch cable. On an 82. With the grab rail. Mine doesn't have a grab rail but it has a luggage rack and trunk which is worse.
YOU'RE THE ONE
YOU'RE THE ONE
- Tom Neimeyer
No BS
Hey, I saw that trick on PBS, Secrets of Great Magicians. Was that you?
- cbxtacy
- Will
Re: clutch cable
How did the clutch cable get involved with the lack of grab rail or did you loop the extra length back there to take up the slack?cbxtacy wrote:I'm so good. Your typical hard working, good looking, intelligent and MODEST CBX owner. My high mileage, mostly stock with sport kit 82 clutch cable was going. I left the tank and seat on, dis-connected both ends of the cable, taped the bar end of the new one to the engine end of the bad one, and pushed and pulled it through. Piece of cake. Remember this the next time you have to replace a clutch cable. On an 82. With the grab rail. Mine doesn't have a grab rail but it has a luggage rack and trunk which is worse.
- cbxtacy
