More petcock queries...
I am trying to cobble together a tank/petcock for a buddy.
What is the position of the rubber stopper inside the sleeve of the plastic gas filter?
Is there a washer required between the threaded tank spigot and the petcock nut? Plastic? Fiber?
Thanks for any info, gents.
The rubber sleeve inside the screen is located at the top of the brass standpipe. There is a thin o-ring that fits in the recess if the tank spigot. It slides down over the plastic screen. It'll leak without it. If you get a strainer set for the petcock from Honda, it will come with the o-ring.
- Kool_Biker
Rubber sleeve inside strainer screen
Dave, you seem to indicate the sleeve inside the petcock screen should be higher than in my picture?daves79x wrote:The rubber sleeve inside the screen is located at the top of the brass standpipe. There is a thin o-ring that fits in the recess if the tank spigot. It slides down over the plastic screen. It'll leak without it. If you get a strainer set for the petcock from Honda, it will come with the o-ring.
At the top of the brass standpipe, i.e. near the top of the screen rather than about the middle as shown?
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Re: More petcock queries...
Aris:
There's more than meets the eye with these. The strainer you show is for the '80-'81 petcock - a '469' part #. The '469' petcock has a 53mm standpipe - to match the location of your rubber sleeve. The '79 petcock has an 80mm standpipe and a differently sectioned strainer with the rubber sleeve higher to be at the top of the higher standpipe. Over here, only the '469' strainer is still available and it only exactly matches up with the '80-'81 petcocks. It could be used with the '422' petcock, I think, by repositioning the sleeve.
You can tell if you have the entire '469' petcock by the outlet - the '469' has a 3/8 inch outlet and the '422' one has a 1/4 inch outlet. And also, of course, by the short standpipe. I suspect you have a complete '469' petcock.
Obviously, the reserve capacity is slightly different between the two petcocks. And the '82 petcock is a completely different unit.
So to answer your original question - the rubber sleeve should be located such that the top of the brass standpipe just slides into it and no further. This is probably more than you wanted to know, but that's the scoop on the differences in the two units.
Dave, Aris,
I just rebuilt my 1979 petcock (422) and had a 1980 (469) to use as a guide. I did not know until Dave's post above that they had different length pipes. Of course, the new strainer I got was the 469 (I did not know these were unique as well), so fabricating a new brass pipe ( the 1979 pipe was pretty much gone) matching the 1980 unit seemed to fit the strainer properly. Ignorance is bliss.
I installed the rubber plug in the strainer before putting the assembly on the brass pipe. There are little molded stops on the I.D. of the strainer to position the rubber plug appropriately. When the assembly is slid over the brass tube, the plug is pretty much right at the end of the tube.
Barry
Barry
- Kool_Biker
Interesting ... Here's what I have.
The rubber sleeve is located positively inside the strainer, but the brass certainly goes through it and stands higher, may be >2cm from memory. You can clearly see the sleeve mark on the tube!
So I guess this arrangement would lead to an earlier 'reserve' condition but little else? And may be hardly worth doing anything about it?
Shortening the original brass tube would be a shame. Am I right?
Cheers, Aris
The petcock outlet is 1/4" so it is a 422, but as you say (see also pic), the strainer is probably a 469. Thanks for pointing out!The rubber sleeve is located positively inside the strainer, but the brass certainly goes through it and stands higher, may be >2cm from memory. You can clearly see the sleeve mark on the tube!
Cheers, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Aris/Barry:
I think you guys about summed up the reality of the whole situation. The only scenario that wouldn't work very well is trying to use the original 422 strainer with the 469 petcock. The standpipe would be too short to engage the rubber collar. I guess this falls into the 'mostly useless trivia' category!
