Gas Tank Operation
Posted: Thu Apr 10, 2008 9:20 pm
by DevonCbx
Does anyone know what is happening in a tank with the fuel cock on and then reserve? How does this work. Is the reserve a seperate internal tank or is it to do when the tank gets low to a point and then the reserve kicks in?
Posted: Thu Apr 10, 2008 9:30 pm
by Terry
The reserve position pickup inside the tank is lower than the regular position. One tank holds all the fuel. Always a good thing to run the bike in the reserve position every fillup for at least a few minutes. I'd hate to find out that my reserve pickup line is clogged after I had to make the switch on the road. I've also heard that Pingel replacement units have less of a reserve capacity than stock units. An even lower reserve pickup maybe?
gas tank
Posted: Thu Apr 10, 2008 10:14 pm
by DevonCbx
Thanks for the very informative inormation
Duane
Posted: Thu Apr 10, 2008 11:33 pm
by Mike Barone #123
Terry wrote:The reserve position pickup inside the tank is lower than the regular position. One tank holds all the fuel. Always a good thing to run the bike in the reserve position every fillup for at least a few minutes. I'd hate to find out that my reserve pickup line is clogged after I had to make the switch on the road. I've also heard that Pingel replacement units have less of a reserve capacity than stock units. An even lower reserve pickup maybe?
Hi Terry/Duane
My experience with the Pingel tells me it is wayyyyyy overrated and in my view a totally inferior replacement to the stock CBX.
The Pingle on my X leaked and it has another nice feature........when you take the tank off for any reason and lay it on a table.........this pushes the lever to the open position and and gas ends up everywhere.
I guess it could get worse if one was working in a garage in cold weather and laid the CBX tank/Pingle combo down with a torpedo heater running nearby. :suspect:
:suspect:
:suspect:
Mike
Fuel Tap
Posted: Fri Apr 11, 2008 3:31 am
by CBXRoger
In the normal 'on' position, the fuel comes from an approx. 2 inch high tube. On my '82 CBX it will drain 4.5 gallons, leaving a gallon still in the tank. The reserve position drains from the bottom of the tank, instead of the standing tube. This should drain the last gallon of fuel.
In practice, I watch when the tank goes "empty" and I am required to switch to reserve. Dividing the miles traveled by 4.5 gallons, will tell you what your average miles per gallon are. That is also the numbers of miles remaining on the tank before total empty.
Gas Tank
Posted: Fri Apr 11, 2008 9:23 am
by DevonCbx
Thanks for the info.
Duane
