Late Model Luggage locks
- jt
What are options for getting keys for these locks, numbering system I have not seen before on Honda locks. Detachable saddlebag lock and saddle bag latch.
Can a key be made by locksmith? Doing a search for these numbers does not come back with anything. Click on it to enlarge pic.
JT In Texas
the mirror every mornin'.
Re: Late Model Luggage locks
It's probably a 211 and/or a 714 key - those locks were all keyed to the rest of the bike and used the same key as the bike they came from. I can't exactly tell what part you are showing there.
- jt
Thanks Dave for the reply, The parts are a latch from a 81 CBX saddle bag and the other part is the Detachable lock that locks the S/bag to the frame.
I'll see if I can find those keys. Would you know if the saddle bag key is the same size as the Ign key or is it shorter looking?
Thanks again
Thanks again
JT In Texas
The bags use the very same key, bag locks and slider pin locks, as the ignition/gas cap. All one and the same. If your ignition key doesn't work for the bags, either the ignition switch has been changed; or, the bags and/or retainers are not original for that given bike. Applies to the helmet lock, also.
- jt
Thanks Larry, good info. yes the bags and the racks are not original to the bike, just trying to get keys so they can be used.
JT In Texas
If you provide the correct lock number to a good locksmith, they can cut a key from that code.
- jt
Dave, I found those two key #'s 211 & 714 on Ebay, so I'll let ya'll know if that works out .
Thank you !
Thank you !
JT In Texas
- jt
Dave,daves79x wrote:It's probably a 211 and/or a 714 key - those locks were all keyed to the rest of the bike and used the same key as the bike they came from. I can't exactly tell what part you are showing there.
You were spot on, got the keys and they work great.
Thank you !
JT In Texas
Can a replacement '82 gas cap be rekeyed to match my original ignition key?
I am pretty sure it can be.hondaman160mph wrote:Can a replacement '82 gas cap be rekeyed to match my original ignition key?
