20 tooth offset countershaft sprocket
cbxtacy wrote:The fan clutch on my truck won't engage to spin the fan. If I sit there idling, the engine overheats. When I'm moving it's okay with the breeze blowing through the engine bay but it was warm and muggy in Austin, TX last night.
George: That is really strange. The fan clutches in these big Internationals are pneumatic and they are set up with the failure mode engaged, i.e.: if no air pressure, the fan runs all the time. It makes sense this way. if anything is wrong in the control circuit the fan should run all the time, rather than stopping.
cbxtacy
Post by cbxtacy »
Sorry, Mike, the fan don't engage. I'm sitting at the Flying J in Texarkana, AR without a load and sweltering (it's not really too bad and I can go inside if I want to) because the engine will shut itself off after about 15 minutes idling.
I really believe if you catch an emergency flight to Texarkana and repair my truck, your company will re-imburse you. Would a truck driver lie to you?
YOU'RE THE ONE
dan1995
Amazing Poster
Amazing Poster
Post by dan1995 »
just be thankful it's not july :lol: :lol:
Dan 1995
Triple x owner 79,81,82
Ironbutt member #24745
Coast to coast and border to border on a CBX
My goal was to ride farther and faster than my wife could bitch....
I needed a faster bike....
So I got a BUSA!!!!!
George, there is indeed a system on the older trucks ( I just assumed you had the latest and greatest equipment) where the solenoid needs air to engage the fan. In any case, there should be a way to lock that fan into the running mode.
Some trucks have a fan clutch control bypass switch in the cab.
If not, try to find the solenoid. It may either be on the firewall or close to the fan in front of the engine. You can locate it by tracing the wires from the fan clutch. If you disconnect these wires, the fan should run. I hope.
cbxtacy
Post by cbxtacy »
There's a fan override on the dash. When I flip it, the light comes on but the fan still does not turn. If it get's hot, I'll look for the switch mechanism under the hood. It's a 2001 International with over 700,000 miles. Time to sell it and buy a new truck.
YOU'RE THE ONE
415ZR1
Re: 20 tooth offset countershaft sprocket
Post by 415ZR1 »
Offset
Louis
Amazing Poster
Amazing Poster
Post by Louis »
George, Here are some made on ebay. Go to CBX WORLD and check under items for sale and you will see what we are talking about. #140044203987 Louis www.usedcbxparts.com
