18" wheels on '81
rancheroxl@yahoo.com
18" wheels on '81
Post by rancheroxl@yahoo.com »
Has anyone out there ever done this? Does it help the handling? I thought I questioned this earlier, but can't find it. Craig
Mike Barone #123
is smaller better????????/
Post by Mike Barone #123 »
hi craig
i will give it a go with what i know first hand with an 18" on the front of a cbx and a 17" rim on the back
smaller rims (18" on front and 17" on back) will help the cbx turn in and come back up be faster
smaller wider rims (18" x 3.0" =110 tire on front....and.... 17"x 4.5"/5.0" = 160 tire on back) will make x turn in and back up be far more predictable and stable
just converting the rims to 18" or per you q will get you part way there....after this if you have an early model and like to ride fast you need to can the 35mm forks and replace them with 39mm
basically an 1100f front and back replacement (kosman widened rear rim to 4.5 or 5.0 inches will solve most if not all early model problems. frame gussetting and a steering damper are a plus but all of this without replacing the 35mm tubes wont get you where you want
if you want to see what this looks like on a cbx.......check the dawgie out...sorry in advance this is not a show bike for sureeeeeeee ....but doesnt do too bad in the turns and tights stuff in the mtns here in the east
go here photoisland.com
password and id are mabarone cbx
e me on any further q....... team222@paonline.com
mike
