Where does this go???
Posted: Fri Apr 29, 2022 5:41 pm
by Bill Kemp
I have taken the rear wheel off my 1980 Honda CBX and installed a new tire. When I was removing the wheel I pulled the long bolt out and spacer/bushing fell to the floor and I cannot figure out where it goes.
I think it goes somewhere by the rear brake caliper mount but am not positive. I want to ensure things are correctly installed.
I have looked at all the service manuals and parts diagrams on the internet with no luck.
Here are a couple of photos of the part.
Appreciate any help
Bill Kemp
Re: Where does this go???
Posted: Fri Apr 29, 2022 8:48 pm
In the stock schematic part #8 is the wheel collar.
Could it be with the Lester rims on your bike this is the replacement?
https://www.ronayers.com/oemparts/a/hon ... rear-wheel
Posted: Fri Apr 29, 2022 9:07 pm
by Bill Kemp
I figured it out.
It goes on the chain drive side.
It goes between part number 1 and part number 7. It is the only way that my tire is centered and allows for the brake caliper holder to fit nicely over the rear brake rotor.
Here are some pictures
At first I thought it went between the brake caliper holder and the right swing arm area. That did not work as the brake caliper holder would not line up with the rotor
Then I though it went on the other side of the brake caliper holder but that was worse
Then I put just the caliper on the frame of the bike to see where it needed to line up with the rotor. Once that was done I could see that the tire needed a spacer on the chain drive side to center it between the swing arm legs.
The power of deduction I guess.
However
If someone know better please feel free to help me out.
Bill
Ps. Perhaps this might be an extra spacer for the Lester wheel and that is why it is not shown in any parts diagram. Just guessing though.
I should have taken pictures before I took it all apart like I normally do
Bill
Posted: Fri Apr 29, 2022 9:24 pm
by Bill Kemp
Tomorrow I might see if I can take some measurements of the distance from the center of the hub to the inside of each swing arm leg to see if the wheel is perfectly centered between the swing arm legs.
That way I can be sure it is all correct.
It is getting late now in Toronto but at least the wheel is on and I can move the bike around in the garage and get it out if the way for my wife.
Bill
Posted: Sat Apr 30, 2022 6:43 am
That has to be a Lester part, it is for sure not stock CBX. The Lester hub must be narrower.
Posted: Sat Apr 30, 2022 8:49 am
by Bill Kemp
Do you know if there is any washer or spacer that goes on the very far right side (brake side) between the black caliper mount and the chrome chain adjuster. In all the diagrams I see it never shows the whole brake caliper and wheel assembly installed together.
They show them separately but not together. I would like to know if the black caliper mount touches the chrome chain adjuster or is there a washer installed in between.
Can you post a picture of this area on your bike please for me to see as tyatbwould be very helpful.
Bill
Posted: Sun May 01, 2022 7:21 am
No washer there. Spool spacer on the left, top hat spacer on the right, caliper hanger and chain adjusters. That's it. But you have the additional Lester (apparently) spacer, so it's hard to know what is correct for your set-up.
Posted: Tue Aug 09, 2022 12:50 pm
by wyly
When I remember to do so I find it helpful to taking pictures during the disassembly procedure to be invaluable.
Often when I take something apart I find some part needs replacing which usually requires time to acquire, by the time it arrives I've forgotten what goes where and in what order.
