Rear wheel binds when torquing axle nut
Posted: Sun Jul 05, 2020 6:37 pm
Greetings,
Just replaced rear/front tires and rear brake pads and bled. Braked work fine. Torquing down the axle nut results in rear tire/wheel assembly very reluctant to turn freely with no binding. Relax torque, and axle turns as usual. Chain adjustment is accurate via adjustment marks and measuring between axle nut and swing arm bolt. All spacers are in and orientated as required. Could bearings be binding up some how?
