Idiot lights restoration
- Kool_Biker
Hi
Is there a simple way to restore the lettering on the instrument cluster idiot lights? Thanks
Aris
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
- Don
- Amazing Poster
Re: Idiot lights restoration
Try masking a small rectangle as close around the lettering as possible
Spray paint that white - Let dry a day or two
Sand off the paint using wet or dry paper and plenty of water. Begin with #600 but stop before all the extra white is gone and then work your way through #'s 1000, 1500 and 2000 and by the time the extra white is gone, the plastic should look like new . . . . with the new white paint left only in the lettering
- Kool_Biker
Hi Don
This makes a lot of sense assuming the original lettering 'wells' (for lack of a better word) are still there.
In my case these are absent, 'polished out' I guess through numerous cleans near the ends of the words (see below), and hence this method might not work. Any more ideas?
I remember once contacting Letraset, being pleasantly surprised by how few custom sheets with words etc one could order at what seemed then reasonable cost ... but it's been some time.
Aris
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
- Don
- Amazing Poster
Aris,
My bad - From your close-up photo, it appears there never were any 'wells' and that the white lettering was stencilled on as opposed to paint sitting in grooves - Probably why it wears off so easily
It's gonna be much harder to get them to an original condition than we thought
It might be possible to take them to an engraver and have him engrave grooves in the plastic, which you could then fill with paint using the above method. Maybe buy a spare or two to try that method and see how it works out, so you don't mess up your originals. I would try to get an extra pair of the amber turn signal ones and see if you can get the 'TURN' engraved in them and see how they look when you're finished and then go from there - You could wind up with them looking better than new
Aris,
If you could get a precision cut custom stencil made from vinyl or ?, you could apply new letters with screening or spraying.
There are lots of precision masking capabilities in the semi-conductor industry. I don't know if the custom vinyl sign cutters would be capable.
If someone invested in these stencils, a lot of owners could polish up the indicator faces and apply new wording.
Barry
Barry
- Don
- Amazing Poster
That would be cool . . . . but it would be hard to reuse a vinyl stencil due to the tiny, separate bits inside the 'B', 'R', 'O' and 'A's on the light covers. I don't know if the engraving process would be practical, but it might be cheaper than having custom dercals made. I suspect the engraving process would be more permanent though than either stencils or decals
- Kool_Biker
Thanks for all suggestions.
I have no idea who to turn to to engrave these pieces of plastic competently, although it would be a nice challenge
Seems to me using 'Letraset' (not sure if they use the same Brand name in the US, they are big in Europe) decals, protected by a suitable varnish might be a good and doable solution, at least where I live.
I agree, a good repeatable solution would benefit many of us.
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
An itty-bitty silkscreen would be the shizzle. It would be fiddly as heck, but I imagine that if you completely sanded/polished off the old lettering, you could silkscreen on some durable ink in pretty close to the original position. A custom Letraset run might be more practical. Once upon a time there was an photomechanical process called 'wash offs' that produced something similar. It used some chemicals that literally gave me a prickly feeling in my brain, so I imagine it's long-since outlawed, at least in the USA.
- Amazing Poster
I do have new ones if you decide to go that way.. Will even take your old ones in trade. Email me at usedcbxparts@hotmail.com Thanks, Louis
Good morning, does anyone know where to buy new lights for the gauge cover? I need blue, red and green
If you have your originals, you can send them to Marcel Den Butter at cb750faces.com and he will restore them for 10 euros ea. He is doing 3 sets for me now, will post pics when I get them back.
