Kent restores an '81
kbart1
Re: Kent restores an '81
Post by kbart1 »
thats what i think it is as well but i have tried several different ways and cant see HOW it goes on. anybody out there able to send a pic of the underside of a pro-link clutch perch????
thanks
kent
kbart1 wrote:thats what i think it is as well but i have tried several different ways and cant see HOW it goes on. anybody out there able to send a pic of the underside of a pro-link clutch perch????
thanks
kent
Kent, it goes on top. Hope this picture clarifies it.
4973
kbart1
Post by kbart1 »
thanks you guys! clarified and now back on the bike! i was thinking it went somewhere on the bottom side of the perch.
kent
Mike, can i borrow some soap and water?
steve murdoch icoa #5322 wrote:Mike, can i borrow some soap and water?
:D :D Having spare parts makes it easier, Steve. An unfair advantage of being a hoarder, maybe! :think:
Although it took me a while to find it :roll: My parts department is curently not that easy to navigate....
SteveG
Post by SteveG »
Steve - That is what happens when you ride them!
Mike - I volunteer to inventory and sort your parts department. (Not responsible for drool stains on parts!)
Kent - Great build thread.
Steve
kbart1
Post by kbart1 »
o.k. guys
here we go. i am getting CLOSE to bolting things up now so all the little nit-picky questions are going to start. here's where we're at so far just to catch you up. pretty much everything is back on the frame less tins. rebuilt all the calipers and master cylinders and installed the spiegler lines (2 line set-up in the front). all filled with fluid and bled, had one drip on right front caliper. turns out slight turn on banjo bolt to seat crush washer did it. striped out my SOMEWHAT rusty and previously "kreemed" tank with the por-15 HD tank kit and it looks great, very impressed with this product. bill from "tims" set me up with the decals i needed, among other stuff so my painter is going to "paint" the stripes and use stock decals where he cant replicate. have the suzuki 8" headlight i am going to run as i am going naked on this bike, for now. over the Christmas holidays i was watching a set of stock pipes from a zero mile bike on e-bay. for fun with about 5 mins to go i thru in a bid of 600 bucks for the set thinking there was NO WAY i would get them, guess what, i got them (wifes not to happy). here is the first thing i need your help with. can anyone advise a practical or the best way to install these pipes? what with fitting the crossover together then the #2 and #5 cylinder pipes it looks like you have a large mess of chrome to try and fit into place (without scratching it or the head up to much). the manual just says "remove" or "replace" the exhaust system????? do you do one side at a time and try to make everything fit together or do you assemble everything off the bike and try to fit it into place or what? any practical tips here would really be appreciated. next, there was a little "clip" type of thing on the front seem of the gas tank? i think it is originally covered in rubber. what is it and what does it do if anything? i may need 2 more once my tanks painted. as of right now once my tins are back and the exhaust is hung the last thing i need before i can actual ride this thing (which i have not done yet since buying it) is the new chain and sprockets, and a dry day. i know everyone likes pics with the posts so i have included one here but it really doesn't show much progress to the eye unless you look really close and see the new brake lines and freshly rebuilt calipers etc. the main thing is the temporarily hung right side exhaust. although, i am embarrassed to show a pic of my project after seeing mikes pics of the travesty. that looks AWESOME. like jewellery. nice job mike!
thanks guys! any help on this exhaust situation much appreciated.
kent
4967
kbart1
Post by kbart1 »
oops! had the stock rear line mounted here, not the speiglers! trust me, there on there now! :?
Kent:
It's near impossible to mount the Pro-Link system yourself. I've done it, but you really need help. You have to work the crossover together as the pipes are being lifted and set into the head. I've done it a million times and dreaded each one. But nice score on the exhaust!
Dave is right, it is much easier to have help. But not impossible to do it alone. First, you should have a nice padding under the bike to prevent the exhaust from scratching. Lay the pipes under the bike. Lift the front end of one side and fit the header pipes into the ports and secure the exhaust holders slightly without tightening the nuts all the way down. Then fit the other side into the crossover. Watch for the seal. Lift the front end of the other side and loosely connect the holders.
Lift the rear of the exhaust and hang into the bolts. Adjust and align everything and tighten, headers first. Have fun.
SteveG
Post by SteveG »
Kent -
I feel your pain!
viewtopic.php?f=22&t=4718&hilit=+exhaust
But it can be done. Good luck, and have patience. Mike's directions need to be added to the shop manual.
Steve
kbart1
Post by kbart1 »
O.K. so i am officially bored now. waiting for my tins to come back from painter. everything is pretty much bolted up and ready to go once i can get some gas in this thing. in the meantime i'd thought i would post of few pics up to now so you can see whats been accomplished with all your help. hopefully i get tins back soon.
thanks!
kent
4995
4996
4997
4998
4999
5000
5001
5002
5003
So many nice bits, Kent.
It looks great.
The body work will get there just in time for spring.
kbart1
Post by kbart1 »
well we're getting closer
spent today fighting a bad cold but couldn't resist mounting the tins i just got back from the painter. he did an excellent job! just have to figure out my suzi headlight and turn signal configuration. i was hoping to run LED signals but need to figure out how and where to mount them??? anybody have any experience in this area? here's a couple pics.
thanks a lot!
kent
5007
5006
5005
Beautiful, Kent.
This set-up was on my '81 when i got it. Not nice enough for your bike but it works.
