Cam chain tensioners
Posted: Wed Apr 29, 2015 2:02 pm
The official Honda workshop manual is a little vague on the procedure.
From memory, I believe it is set by just pushing in on the adjuster & tightening the lock nut.
I would assume you would want the correct tension on the tightest run of the chain.
Do you turn the engine until this occurs & set the locknut?
What is the correct procedure on adjusting & setting both cam chain adjusters?
