Aluminum crank mounted degree wheel....
Jebbysan
Post by Jebbysan »
Hello!
I am starting to prototype some ideas that I have had over the past few years.....
One is a degree wheel that mounts right up to the crank hex on the right hand side of the motor.
I like degreeing from here much better myself.
I am gauging interest to see if if there is enough to see if I want to see it through.....
It will be all aluminum....and although I don't really want to describe how it holds just yet....It works!
I will keep cost down as low as I can....plus the more I make...the cheaper it is.
I made a mockup for myself and have been using it for 3 years.....and for me it is the only type I would use.
What do you think? Critique welcome.... :text-feedback:
Jebby
1979 CBX Sport Custom
1972 Corvette
1982 wife with a 1982 Z/28
Re: Aluminum crank mounted degree wheel....
Jebby, engine rebuilding is out of my mechanical ability so a degree wheel is not something i would be using.
But thanks for your efforts in making the job better for those people that do.
steve murdoch icoa #5322 wrote:Jebby, engine rebuilding is out of my mechanical ability so a degree wheel is not something i would be using.
Steve: I don't think you have to go into "engine rebuilding" to have use for a degree wheel!
Jebby: Great idea! I would be in for one or two!
Mike, i get that rebuilding an engine is not required for using a degree wheel.
I was just referring to the fact i could not provide any "feedback" or "critique" that Jebby was looking for.
Jebbysan
Post by Jebbysan »
Thanks guys....I know I kind new over here...but this is something I wanted to make for myself....
So why not make more?
I have other parts in the works as well....
Thank You for the feedback....the wheel will be a reality :)
I will fill you in when I get the print done....
Thank you all!
Jebby
1972 Corvette
