Clutch won't release
Posted: Wed Mar 19, 2014 2:13 pm
Hi all,
I'm new to this forum and indeed CBX ownership so it's a great comfort to be able to join such a knowledgeable community of like minded CBX lovers. I'm after some advice if I may in relation to my recently purchased 1979 CBX1000Z.
I bought it as a non runner however I've now got the engine running reasonably OK however I have a more immediate issue with the clutch not disengaging. I've adjusted it as per the instructions in the workshop manual and externally, it seems to work OK in that the handlebar lever is pulling the operating lever on the clutch housing up a reasonable amount and I've looked through the lifter cap and can see the lifter moving in sympathy with the clutch lever being operated however the clutch just doesn't release. If I put the bike in any gear on the stand and pull the clutch in, I can't turn the back wheel by hand and I also tried selecting first with the clutch in and the engine Idling and I simply lurched forward and the bike stalled. I've even over adjusted the clutch cable such that the clutch actuation arm is almost at the limit of it's travel and it made no difference. The clutch obviously rattles at idle and I don't really perceive any reduction in that rattle when I pull the clutch lever in. I was assuming that the rattle should be drastically reduced with the clutch in but may be well wrong on that.
I think the bike was last run about six months or so ago and the clutch was supposedly working at that time. Could the plates simply be stuck together having stood for a while and I just need to remove, clean and replace them (having checked they're serviceable) or is it symptomatic of a bigger problem? I guess I'm going to have to remove the clutch cover and have a look but I just wondered if anyone else had had any experience of this before I do or whether I'm doing anything wrong?
Any help or advice would be very much appreciated.
Best regards,
Jim
Best regards,
Jim
