oil leak
Posted: Mon Oct 20, 2003 3:08 pm
My recently installed engine on my '79 runs well...the problem is an unseen oil leak behind the engine, above the cases. Both oil line connections (head and top of cases) are fine and tight. (Same with oil send unit) Overhead lines are fine. The amount of oil that ran off the top left side of the cases was enough to cover my left boot in an hour! No visible source of leak upon inspection run, ( with a fan blowing on the motor), and me taking it up to 4 grand!
How much oil could blow upward through the crankcase vent connection hose if it is looser than appears? I actually had a puddle on top of the cases! My '76 triumph never does this!
I am stumped? Any ideas? Tom R
