Timing
Motoguy@64
Timing
Post by Motoguy@64 »
Have just put in Dyna Ignition. Engine runs but when I do dynamic timing F line is always at about 12 oclock instead of at 3 where the engine seam is.Moving ignition plate does not seem to have any effect. Have been timing Chevys for years, but I have no clue in this case. HELP..
Re: Timing
Is this a fresh rebuilt motor or a stock motor that was running fine before you installed the dyno ign ?
Motoguy@64
Re: Timing
Was running fine until spark units croaked. It does run now, and on all 6!!,but the"book"says "set the timing". I thought, piece of cake. Not so much!!!
Re: Timing
Are your springs and weights moving freely on the advancer, what year CBX and what's the number stamped on your advancer?
