valve clearance
Posted: Tue Jun 28, 2011 9:59 pm
Just getting ready to adjust the valves on a 79X that had been sitting for about 20 years, put about a 100 miles on it after I got it running before I checked the clearances. Most of the valves are in the .006 to .008 in. range, a couple at .005 and one at .004. Two valves are way off at .012 in. is this an indication of excessive carbon buildup or just shim or cam wear. Am I safe to shim as close to .oo3 in. as I can get or is it best to stay on the loose side. I was going to leave the valves at .004 and .005 alone. Any suggestions or comments will be appreciated.
