Aligning front hanger bolts
Jacked up the 79 engine into place today but had trouble locating the last front top engine hanger bolts on each side, jacking the engine higher just resulted in the whole bike starting to lift. Instead I just let the front tire down slowly (with jack still in place) everything then lined up perfect....probably luck but it worked....hope that is another solution to help prevent stripping out those threads in the frame!
- cbxtacy
- alimey4u2
- ICOA Web Video Director
- cbxtacy
I put a block of wood just to the rear of the oil filter and use a jack to jack the engine up and down while I line up all the bolts and brackets that hold it in place.
YOU'RE THE ONE
YOU'RE THE ONE
