1982 clutch thrust washers dimensions
bkweis
Post by bkweis »
I am looking for the dimensions for the clutch thrust washer for a 1982 cbx. I do know the inside diameter 30mm but need the outside diameter
and the thickness or if some body might have two of them I can buy. Thanks Brian Weis #2516
SteveG
Post by SteveG »
Hi Brian,
Don't know if this helps, but my 82 parts list shows the part # to be 90458-MA2-000 (Thrust washer, 30mm, quantity 2).
Good Luck. Steve
Brian, I will measure one, but I think the outside diameter is 30mm, not the inside. Consider 30mm are 1 1/4 inch!
piit
Post by piit »
EMS, did you measure thrust washer? Would be interesting to have thickness on it.
:oops: :oops: Oops! Will do tonight...Sorry
piit
Post by piit »
No problem, it is winter here and time to wait :wink:
piit
Post by piit »
EMS, the spring is coming :D
:D :D Outside diameter 44.9mm (44.5mm), inside diameter 30.1mm (30.0mm), thickness 0.92mm (0.86mm). I am not 100% sure whether this is the 422 or th MA2 part, however. :oops: I have two of them loose in a box, not with a clucth assembly
piit
Post by piit »
Thanks EMS! Thickness is the open issue for me. I do not know have the MA2 2xwashers same thickness as 422 washer. I will measure the 422 washer and compare against the figures you gave.
piit
Post by piit »
422 washer; OD 42mm, ID 30.1, thickness 1.6mm. So, seems that EMS´s washer is from MA2.
piit
Post by piit »
EMS; PM sent!
bkweis
about clutch thrust washers
Post by bkweis »
I would like to thanks everyone for the imformation on the clutch washers.
That is alot of good information . EMS I will see you in Columbus next weekend. thanks Brian
Brian:
Apparently my messages to you never got there. I do have an early model clutch sleeve for you to modify. I'll bring it this weekend.
bkweis
about washers
Post by bkweis »
Hi dave I did not receive any of your messages. Chuck and I will both
be there fri. evening. looking forward to this winter meet.
Thanks Brian
piit
Post by piit »
Seems that you gurus do not know the PL washer thickness or you are hiding it :shock:
I have tried to get this data almost two years without success. This post was not started by me, but the result seems to be same as earlier :cry:
