back firing
DevonCbx
back firing
Post by DevonCbx »
I pulled my plugs to check them out. They seemed to have normal wear except for Cyl 01. This plug was really fryed. Is this a sign of too rich or too lean. Also can someone explain if the carbs burn leaner or richer in what direction to turn the jet screws.
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Devon, when you say "fryed" what do you mean ? Here is a chart to help...
http://www.classic-car-magazine.co.uk/a ... chart.html
Idle adjustments are air jets therefore screw out to weaken & in to richen. Maximum adjustment is 1 1/4 turns from closed but wait for someone to varify as I'm rubbish on Keihins...
However, it is highly unlikely that the idle jet range will damage a plug, unless idled for a very long time... The engine is not under load..
alimey4u2 wrote:Devon, when you say "fryed" what do you mean ? ..
No results found for fryed.
fried Pronunciation Key - Show Spelled Pronunciation[frahyd] Pronunciation Key - Show IPA Pronunciation
–adjective 1. cooked in a pan or on a griddle over direct heat, usually in fat or oil.
2. Slang. a. drunk; inebriated.
b. intoxicated from drugs; high.
c. exhausted or incapacitated through intemperance; burned-out.
:D :D :D
alimey4u2
Post by alimey4u2 »
Keep the questions coming Devon, we are all here to help.... :wink:
spencer
Post by spencer »
Larry said "Idle adjustments are air jets therefore screw out to weaken & in to richen."
I know Larry is an experienced carb technician, but I think the idle adjustment screw on a stock CBX carb is a fuel screw, not an air screw. As such, turning them clockwise (in) leans the mixture, and turning them counterclockwise (out) enrichens the mixture.
Being relatively inexperienced, I could be wrong, but I just looked at my old Honda carburetion video, and it seems to indicate that the screw is a fuel screw. A fuel screw is located between the slide and the engine. An air screw is located between the air cleaner and the slide.
Correct me if I am wrong.
SCH Rochester, MN
alimey4u2
Post by alimey4u2 »
I too am not sure Spencer, as I said before, I'm sh!te at Keihins.... :oops:
What it does say for this forum is that people are comfortable to disagree... 8) :thumupp:
spencer
Post by spencer »
That's why it is so great to be able to come here and ask questions of all the experts like you. :bow:
SCH Rochester, MN
alimey4u2
Post by alimey4u2 »
After almost 30 years with the bike I too am still learning from others.... :wink: :thumupp:
Mmmmh! :? I always thought IN is leaner, OUT is richer.. :?
alimey4u2
Post by alimey4u2 »
Looks like you guys are right, I always thought it was an air mix adjustment not fuel.... :oops:
