Top End Reconditionaing
Posted: Sun Jul 20, 2008 8:57 am
Symptoms:
Significant smoking at startup/cold; smoke at idle, cold or at temp. Plugs are fouled at every check. Number 3 worst; number 4 cleanest.
I recently did a compression test resulting in the following:
Cyl initial w/oil
1 135 150
2 145 140?
3 85 90
4 115 115
5 140 150
6 115 145
Valve clearances (MM) :
baseline:
Cyl exh a exh b int a int b comment
1 .10 .10 .10 .10 loose
2 .10 .10 .10 .10 loose
3 .10 .10 .09 .10 loose
4 .09 .10 .08 .08 loose/ok
5 .10 .10 .10 .10 loose
6 .10 .10 .10 .10 loose
My assessment is:
1. worn rings; valves (seat) marginal
2. leaking valves, marginal rings
3. leaking valves, worn rings
4. leaking valves, marginal rings
5. worn rings, marginal valves
6. worn rings, marginal valves
Ok, so the head is off, disassembled. Chemical warfare was unsat, so I bench-grinder-wire-brushed the valves clean. I used rubbing compound to clean the very-hard glaze off the exhaust valve heads. I removed the old seals for replacement.
What is the best way to remove the pesky washers from on top of the valve guides?
I am dremal-brass-wire-brushing the chambers and ports. Then, I am planning to lightly port and polish the exhaust and intake ports using my dremal arsenal. Thoughts on this appreciated.
Cylinder Honing
I found what seemed to be a pretty good article on honing cylinders.
http://www.babcox.com/editorial/ar/eb110242.htm
I bought a 3-stone unit from the local auto parts store.
1. What is the best honing lube; engine oil?
2. How tight should I set the hone?
3. Any thoughts on "plateau finishing" as described in the article?
After honing I plan to mic bores and ring gap to ID replacement rings. Thoughts?
Valve Clearance Target:
1 .07 .07 .07 .07
2 .07 .07 .07 .07
3 .07 .07 .07 .07
4 .07 .07 .07 .07
5 .07 .07 .07 .07
6 .07 .07 .07 .07
Thoughts?
Thank you.
/r
Brad
Cyl initial w/oil
1 135 150
2 145 140?
3 85 90
4 115 115
5 140 150
6 115 145
baseline:
My assessment is:
Cylinder Honing
1 .07 .07 .07 .07
2 .07 .07 .07 .07
3 .07 .07 .07 .07
4 .07 .07 .07 .07
5 .07 .07 .07 .07
6 .07 .07 .07 .07
Thoughts?
Thank you.
/r
Brad
