I noticed that about every 2 to 300 kms I may be using a half a liter of oil. Is this normal? I believe the motor has about 50 t0 60 thousand kms on it? Also every once in awhile I will red line it through each gear. I understand that this should not harm the bike?
Duane
Oil use
Correct, high revs don't harm the motor. My 79 uses a bit of oil as well and has nearly 50,000 miles on it. The left front top corner where the head seals to the barrel leaks a bit also. Until the power goes down or I start smoking, I'm not worried about it. I've heard that the early Z models had rings that hugged the pistons more than they scraped the cylinder walls and the valve guides can't be in very good shape after 50,000 either. But, until she slows down or begins smoking, I'm riding! Taking the 79 out for a ride tomorrow as a matter of fact. Got her all cleaned up and the weather's nice so off I go.
Reason: Cleaned up HTML for PHPBB3
- alimey4u2
- ICOA Web Video Director
