interesting article in Cycle years ago
Posted: Fri Jan 04, 2008 1:49 pm
by cbxtacy
http://www.cbxclub.com/davespage/cyc80-1.html
and here's a quote from the article that explains why all my CBX's run soo good. 13 row stacked plate oil coolers make about a 100 f difference in oil temperature. And the difference gets bigger the hotter the day and harder you ride the bike.
The correction factor can compensate for day-to-day changes in air density and humidity to give consistent results, and temperature has a bearing on the correction factor because air density is a function of temperature and barometric pressure. But temperature can have a much more decisive effect than its relation to the correction factor. Some engines - like the CBX - are very heat sensitive. Remember, by Honda's own dyno data, a 25-degree hike in head temperature caused the peak horsepower to fall from 74.47 to 68.07. The CBX taxes the blower-cooling system at the Webco dyno anyway, and that's been a matter of record since Honda's engineers witnessed the first dyno of the CBX there back in 1977. Hot dry air - 116 degrees and very little humidity - would be just the thing to cause the CBX to get weak knees. The temperature difference alone 116 degrees F versus 86 F) was enough to explain how the same CBX engine could make 71.59 horsepower on one day, and 77.21 horsepower on another.
Posted: Fri Jan 04, 2008 5:35 pm
by alimey4u2
Mine must be making 150 bhp over here..... :lol: :lol:
Intake charge temperature
Posted: Fri Jan 04, 2008 10:41 pm
by Tom Neimeyer
The temperature of the intake charge has a tremendous effect on the horsepower, here is a quote from an article on "making horsepower"....
For every 10 Degrees F reduction in intake charge temperature, a 1% increase in power will be realized. Example: A 400 HP engine with an intake temperature drop of 70 Degrees F, would gain approximately 30 HP on the cooling affect alone.
Which is why a blow through turbo (which can be aftercooled) can make more HP than a draw through (can't be aftercooled because fuel will condense on the runner walls).
Cheers, Tom
