A little different this time.
A friend has a CBX[yes it is mine] that has been using full synthetic motorcycle engine oil for 10 years. I changed the oil and filter and mistakenly used SEMI-synthetic.
Can i expect any problems?
How about if i had used non-synthetic? [i didn't]
Thanks for any input.
Oh no, not another engine oil question...
- Mike Barone #123
Hi Steve
My thinking is both Synthetic and Semi-Synthetic offer superior performance to the Non-Synthetic that every Honda CBX came from the factory........ so there should be no problem.
If you want that warm and fuzzy feeling vs thinking about this, I would recommend thinking about draining the Semi-Synthetic and use it in your car or lawn mower and put full Synthetic in the CBX.
Best
Best
- alimey4u2
- ICOA Web Video Director
Semi-synthetics are blends with a maximum of 30% synthetic base stock. Any semi-synthetic should be compatible, i.e.: "mixable" with petroleum based or full synthetic oils. The only disadvantage I can think of is, that you may not have the same protection against deposits as the synthetic provided that you used for years. But for one change cycle, you should be fine. ![Question :?:](./images/smilies/icon/question.gif)
