Piston Ring Compressors
Posted: Wed Mar 07, 2007 7:21 pm
by Passx
Guy's,
What do you guy's do about ring compressors when putting the cylinders on ? I have several ring compressors from building automotive engines but of course they are all to big for the X and no one seems to offer one small enough, kind of gives a fella a compleX.
Steve P.
Posted: Wed Mar 07, 2007 7:27 pm
by Terry
Posted: Wed Mar 07, 2007 8:39 pm
by Chris
I used the shim stock/zip tie method on my recent engine build. I would have loved to have had the regular Honda clamps.
The shim stock method worked but I can see where the clamps would have been a huge time saver and I would have used less profanity. :)
Re: Piston Ring Compressors
Posted: Thu Mar 08, 2007 9:43 am
by Mike Barone #123
Passx wrote:Guy's,
Steve P.
Hi Steve
Thx Terry for the research on this for us and that link
Below are two other links with photos and videos that have some ring compressor tools for you to check out.
viewtopic.php?t=2447
viewtopic.php?t=2444
See PM I just sent you on this
Mike
Ring Compressors
Posted: Thu Feb 21, 2008 1:27 am
by big al
Jay Wright from Bare Bones Machine came up with a brilliant way to do this. We tried just using hose clamps and ended up breaking a ring. So we got some shim stock (only about .010" if I remember right) and cut six strips just long enough to wrap around the pistons one and a half time. Spray em with WD40, and make sure you have a second set of hands. It took about an hour of very delicate maneuvering, but you can just undo the hose clamps once the rings are all the way in the cylinder.
NOTE! Make sure the little horizontal pin that locates tha cam-chain tensioner is in place before you put the cylinder on!!!! Don't ask me why I remember this.....
Posted: Thu Feb 21, 2008 3:29 am
by alimey4u2
A wrap of brass shimstock, clamped with plastic cable ties does the trick for me...
PS, Excuse my manners, welcome to the site
big al ....
Re: Ring Compressors
Posted: Thu Feb 21, 2008 7:53 am
by broook
big al wrote:NOTE! Make sure the little horizontal pin that locates tha cam-chain tensioner is in place before you put the cylinder on!!!! Don't ask me why I remember this.....
I thought it was only me did stuff like that.
I used a set of "punch lok clamps" the kind pipefitters use to clamp rubber hose to pipe nipples. Cut the clamp part off and bend the two ends out to hold the rings in tight.
Posted: Thu Feb 21, 2008 8:14 am
I have a friend who has original Honda piston ring compressors that I can borrow if I need them
Posted: Fri Feb 22, 2008 7:19 am
by cbxtacy
beer cans/hose clamps (don't empty out a six pack just prior to engine assembly).
Posted: Fri Feb 22, 2008 8:37 am
I have the original Honda ring compressors and it took me about 15 minutes to install a cylinder just last week - and you can do it by yourself! As always, an extra hand never hurts, however.
I don't know if the Honds ones are still available, but they sure are worth their weight in gold.
ring compressors
Posted: Fri Feb 22, 2008 10:28 pm
by Mike Nixon
EMS wrote:I have a friend who has original Honda piston ring compressors that I can borrow if I need them
The original should still be available, if costly. If not, Yamaha uses the same kind.
Posted: Fri Feb 22, 2008 10:30 pm
by Mike Nixon
daves79x wrote:I don't know if the Honds ones are still available, but they sure are worth their weight in gold.
Then I must have a gold mine in my toolbox...I collected most of the ones available, including the CBX size, back when I was using them for a living.
Posted: Mon Oct 06, 2008 8:19 am
by cbx6ss
As I prepare to install my new pistons, I frantically scan the forums for piston install best practices lessons learned, I am exceedingly envious of Mike's picture...
I will attempt using the beverage can, plastic tie method.
/r
Brad
Posted: Tue Oct 07, 2008 5:13 am
Brad:
If you are coming to the Luray rally this weekend, I'll bring my official Honda CBX ring compressors for you to take home and use. Let me know.
