Piston Ring Compressors
Guy's,
What do you guy's do about ring compressors when putting the cylinders on ? I have several ring compressors from building automotive engines but of course they are all to big for the X and no one seems to offer one small enough, kind of gives a fella a compleX.
Steve P.
Steve P.
- Amazing Poster
- Mike Barone #123
Re: Piston Ring Compressors
Passx wrote:Guy's,
Steve P.
Hi Steve
Thx Terry for the research on this for us and that link
Below are two other links with photos and videos that have some ring compressor tools for you to check out.
viewtopic.php?t=2447
viewtopic.php?t=2444
See PM I just sent you on this
Ring Compressors
Jay Wright from Bare Bones Machine came up with a brilliant way to do this. We tried just using hose clamps and ended up breaking a ring. So we got some shim stock (only about .010" if I remember right) and cut six strips just long enough to wrap around the pistons one and a half time. Spray em with WD40, and make sure you have a second set of hands. It took about an hour of very delicate maneuvering, but you can just undo the hose clamps once the rings are all the way in the cylinder.
NOTE! Make sure the little horizontal pin that locates tha cam-chain tensioner is in place before you put the cylinder on!!!! Don't ask me why I remember this.....
Re: Ring Compressors
I thought it was only me did stuff like that.big al wrote:NOTE! Make sure the little horizontal pin that locates tha cam-chain tensioner is in place before you put the cylinder on!!!! Don't ask me why I remember this.....
I used a set of "punch lok clamps" the kind pipefitters use to clamp rubber hose to pipe nipples. Cut the clamp part off and bend the two ends out to hold the rings in tight.
- cbxtacy
- Mike Nixon
ring compressors
The original should still be available, if costly. If not, Yamaha uses the same kind.EMS wrote:I have a friend who has original Honda piston ring compressors that I can borrow if I need them
- Mike Nixon
- cbx6ss
