How to keep gaskets from sticking to the engine case...
Posted: Mon Jan 01, 2007 1:05 am
by BayArchitect
What is a good product to apply to a side cover gasket to keep it from sticking to the engine case? I've noticed these gaskets can really stick, and it's not easy to scrape an old gasket from the thin edge of the engine case without damaging the finish...or worse. Thanks for your help!
Posted: Mon Jan 01, 2007 5:26 am
by alimey4u2
They stick due to carbon, I suppose you could saturate them in a very high temp grease whiich may aid removal......
Posted: Tue Jan 02, 2007 11:10 pm
by sixofsix
Hey BA:
An old mechanic's trick is to use Nickel Based Never Sieze. This stuff helps the gasket to flow when cinching it up, and the covers never leak AND they fall right off when you remove them! No gasket scraping required.
I've been doing this for years at work on gearboxes and compressors, etc.
PS I'd go with the crush type exhaust washers.... :)
Posted: Wed Jan 03, 2007 8:15 pm
by Rick Pope
Another trick is to lightly apply silicone to the gasket. By lightly, I mean put a dab on your finger, then wipe it around the gasket as though you're trying to wipe it back off. This microscopic film will let the gasket release later.
I've never tried silicone grease, but it may work as well.
My rule of thumb when using silicone is that if you can see it after you snug things down, you used too much.
Posted: Wed Jan 03, 2007 10:08 pm
by Jeff Bennetts
Posted: Thu Jan 04, 2007 7:58 am
by Rick Pope
Jeff,
You're probably right, again. I've never used Hylomar, but everyone I know who's tried it, keeps using it.
Maybe I should pry open my wallet and try it too?
After some research...
Posted: Thu Jan 04, 2007 6:46 pm
by BayArchitect
Looks like "Never-Seez Pure Nickel" by Bostik might be a good choice for gasket release problems. Anyone have any experience with this product? I saw the Hylomar page, but it looks like a gasket sealant, and not a gasket release product. Any comments?
Posted: Fri Jan 05, 2007 7:33 pm
by Chris
Another X'er recommended that I try Gasgacinch. I finally got a can of it.
Its a gasket sealer that states (among other things) "affords easy gasket removal".
I'll give it a try and see. :)
Posted: Fri Jan 05, 2007 8:44 pm
by alimey4u2
Personally I have never had luck with the nickel anti siezes, better luck with the copper. That being "Copaslip" which is superb....
Posted: Mon Jan 08, 2007 5:06 pm
by jt
+1 for the Hylomar, I've used it on the valve cover so far.
JT
