"Parts is Parts" the late Frank Purdue
retrex
Post by retrex »
Hi all, I am curious as to engine parts interchange compatibility between the the early and later Xs. Specifically can you swap the heads, jugs, crank, rods and pistons between the two? If so are they direct bolt ons or is some fab work required?
1982 Honda CBX - Mobile and loving it
1981 GS1100EX - Undergoing rebuild
1981 GS1100EX - Rolling rebuild
Why two GS11s? A man doesn't feel like a man unless he has a big pair.
Tom Neimeyer
Interchangeability
Post by Tom Neimeyer »
The crank, rods & pistons are a straight across swap.
The jugs and head may need some modifications. The difference is the '81/'82 jugs and head had larger diameter studs in the middle. You can use them on a '79/'80. If you want to use a '79/'80 head or jugs on a '81/'82 you will need to have the 4 middle holes drilled out larger. It can be done by the average home mechanic with a drill press.
Cheers, Tom
retrex
Part swaping info
Post by retrex »
Thanks Tom
ldgilman
Post by ldgilman »
Yes, thanks Tom...that answered my question also. I love this no waiting :D
ldgilman
Lakewood, CO
