I found this ( http://tinyurl.com/exbwk ) on ebay and have a question for you tech guys.
I bought a 1979 CBX off of ebay that had the hole in the lower crank-case, I got it for the frame, but now I am wondering if would be able to use this case to replace what was busted on the one I have. I know that I will need to replace some innards, but are all of the four years compatible as far as the cases go?
For $35-$40 I was thinking it would be hard to go wrong...
BUT, if it won't work then I have wasted my money.
Help!
Thanks - ~7~
Need help ASAP (Before noon, 12/08/2005) please!
- fasterspider
Re: Need help ASAP (Before noon, 12/08/2005) please!
I am not 100% positive but I do believe the crank case is the same down the line.Seven wrote:I found this ( http://tinyurl.com/exbwk ) on ebay and have a question for you tech guys.
Help!
Thanks - ~7~
I know you can put an 82 engine in a 79 and a newer clutch assembly is another mod for the 79.
Ray#1
The Fasterspider
Slightly modified 79 CBX
Ride Red
The Fasterspider
Ride Red
- cbxdragbike
Engine cases
The only difference in the years of the crank cases is the location of the serial number. The earlier models had back starter, the later models has it up by piston #6. They are 100% interchangable.
Mark
Mark
- fasterspider
Re: Engine cases
Thank you for confirming my what I was not sure of.cbxdragbike wrote:The only difference in the years of the crank cases is the location of the serial number. The earlier models had back starter, the later models has it up by piston #6. They are 100% interchangable.
Mark
That is good to know.
Ray#1
The Fasterspider
Ride Red
The Fasterspider
Ride Red
