Oil Leak Upper Oil Gallery
Watchfuleye
Post by Watchfuleye »
1979 CBX
Oil Leaking from the upper oil gallery hex bolt. Oil leak is pretty bad.
Unsure about tightening this bolt.
Could it simply be the need for a new O Ring?
Any idea where I can pick up a new bolt, I live in Canada.
Any help greatly appreciated
tevan
Re: Oil Leak Upper Oil Gallery
Post by tevan »
Which bolt are you actually talking about? The allen head oil galley plug?
Watchfuleye
Yes that is the one. Upon closer inspection I noticed a crack on the inside of the plug.
Any suggestions where I can purchase one.
Thanks again
They are difficult to obtain.
Might have to look into a repair and a new o-ring.
Depending upon the nature of the crack, some J-B weld might do the job.
jnnngs
Post by jnnngs »
Hi,
You can get replica plugs. So in Europe:
https://www.cmsnl.com/honda-cbx1000-sup ... 40422000p/
SixCenter.NL also has them.
Would expect the CBX specialists in the US would also have them.
Paul.
Thanks, Paul. Didn't know that.
As always, Louis Mintrone at usedcbxparts.com might be less expensive and quicker. Personally, I'd try there first.
