Clutch tool measurements
Posted: Wed Aug 15, 2018 11:27 pm
by sixinoz
Made my own clutch centre nut tool from the dimensions supplied on the forum. However when I go to use it - way too small. Overall outside diameter given as 32mm but needs to be at least 36mm to fit on the nut. Anyone used these dimensions and had it fit?
Re: Clutch tool measurements
Posted: Thu Aug 16, 2018 12:01 am
by sixinoz
Are the clutch nuts available from any source? On closer inspection some previous owner used the hammer and chisel method the remove this nut and now I don't think a tool will remove it.
