Valve adjustment
CBXJOHNNY
Valve adjustment
Post by CBXJOHNNY »
Checked the valves and 10 of them are .008 / .203mm. Can I remove shims and rotate motor and remove another shim to see how many and what size I will need. Or is it one at a time. I don't think I can but want to ask anyway. Thanks
tevan
Re: Valve adjustment
Post by tevan »
You need to take out and mic the shim in there and record it. Then put it back in before you rotate engine.
CBXJOHNNY
Post by CBXJOHNNY »
That's what I thought. Thanks
herdygerdy
Post by herdygerdy »
Hi there CBXJOHNNY,
This may help you keep your hair...
viewtopic.php?f=6&t=9209&p=72173&hilit=Excel#p72173
I use this on every bike I do and it really helps.
Any feedback on it, or errors found, suggestions for improvement greatly appreciated.
Enjoy!
Cheers...Tony.
