Forged H Beam Connecting Rods
Posted: Mon Oct 10, 2016 5:35 pm
Hi,
New CBX conrods from RPE Racing. These are a direct OEM replacement and much stronger than stock. For those of you who have bigger bores (heavier pistons), higher revs or are just after a better than OEM rebuild, this is it!
Not as expensive as carrillo or pauter but just as strong.
These retail for 1050. However if you buy through here we will do 1000 and free shipping. Just send us a PM or post here.
They are also available on Ebay.
Specs:
4340 Forged Chrome Moly steel for highest strength
Shotpeened
H Beam design
Supplied with 200.000 psi 12 point high strength bolts
Bronze Bush little end
Stock (350g) vs RPE Racing (382g) vs Pauter (395g)
Please note also:
"Stock con rod bolts are not designed to be re-used! When tightened properly (and you should do that at any rate), they will stretch beyond their elastic limit. When re-used, they may come loosem, and if they do, it's a major havoc in your engine" - Satanic Mechanic
Regards ,
Paulo
Specs:
Shotpeened
H Beam design
Please note also:
Regards ,
Paulo
