you tell me
- dan1995
- Amazing Poster
- silversurfer1050
I wish I had a kinematices package. Do the cams turn onece for every crankshaft revolution, or is it a 4:1 reduction?
Logically it sounds like the back half is running backwards and the cams would have to be reverse ground if there is indeed a different slope on the exhaust side. Cams will run backwards too - it's all conected.
Does anyone have a broken cam laying around that they could get a picture of the "end" of one of the lobes. I could trace it and blow it up on CAD pretty easily.
Are they different intake from exhaust? ....two pictures....
Is Geogaedes doing this without a set of drawings. My understanding is that is how Sykorski built the first helicopter. They just made drawings later as documentation for the rest of us mortals who had to manufacture them.
A woman at 20 is like ice, at 30 she is warm and at 40 she is hot.
(Gina Lollobrigida)
(Gina Lollobrigida)
On most any 4 stroke engine, it's a 2:1 ratio - Two turns of the crankshaft for every one turn of the camssilversurfer1050 wrote:I wish I had a kinematices package. Do the cams turn onece for every crankshaft revolution, or is it a 4:1 reduction?
On a CBX, since the cams are two piece, driven from the center, perhaps you can flip them 180 degrees (end for end) and install them and then rework the drive gear mounting - That way you could have the cams on the rear head turning the correct direction even though the head is mounted backwards?
- silversurfer1050
