Hi all! I have just purchased an '82 CBX and it is a wonderful ride. However, trouble has struck and I need some advice. Knowing how hard all older Honda 4 and 6 cylinder engines are to start, I try to start the CBX every other day. Went out yesterday, and it will not start. Finally get it started and it has a miss. Header number three is cold. I ran through the ignition trouble shooting stuff from the manual and found that the 1-6 and the 2-5 spark units do not behave as the manual states. In the manual it says that after grounding the proper pin in the 6P coupler, you should notice a drop in the voltage from ~12V to 0-2V. Only on the units does this. The 1-6 has no drop and the 2-5 drops only to ~10V. I then tested the pulse generator. The unit for the 1-6 sparks weakly, and the 3-4 sparks very strong. I haven't tested the 2-5 unit yet, but will soon. Now for the questions. 1) Should I replace the spark units based on the tests or did I do something incorrectly? 2) Should the pulse generator be replaced due to the weak spark on 1-6? 3) I am assuming the cold pipe is probably due to no fuel reaching #3, since its sister cylinder is running fine. Any help you can lend will be greatly appreciated.
Jeff
CBX is missing....
Jump to
- ↳ New Users Start Here!
- ↳ Daily Discussion: By, For & About CBXers
- ↳ No Redeeming Value
- ↳ Project Threads
- ↳ Rally & Ride Questions & Post Event Reports
- FORUM USER TIPS, HELP DESK & POSTING TEST LAB
- ↳ Help Desk Questions for Using Forum
- CBX TECHNICAL LIBRARY: Answers For All Your CBX Questions
- ↳ New Users - Start Here
- ↳ BRAKES: Calipers, Pads, Lines, Rotors, Upgrades & Fixes
- ↳ CARBS: Cleaning, Rebuilding, Swaps, Aftermarket, Tuning, Syncing, and More
- ↳ ELECTRICAL: Alternator, Batteries, Headlights, Switches, Tailights, Wiring....
- ↳ EXHAUSTS: What works and fits...and what doesn't.
- ↳ ENGINES: Maintenance, Performance, Parts Sources
- ↳ HANDLING: Suspension, Gearing, Frame Bracing, Non X Handling Part Upgrades, Rim Replacement Options, and more
- ↳ OILS: Specs, Opinions, Preferences, and more
- ↳ RESTORATIONS: Tips, How To's & What Not to Do. Parts, Decals, Painters, Paint Codes, Painting Tips.....More
- ↳ TIRES & RIMS: Tire Brands, Mileage, Performance, Sizes, Interchangeability with other models
- ↳ X ...OTHER TECHNICAL: Won't Run, Centerstands, Chains, Fairings, Tanks, Gauges, Petcocks, Seats, Turn Signals, etc.
- ↳ RIDER GEAR: Boots, Gloves, Helmets, Jackets, Leathers, Rainsuits, Textile Suits
- ↳ CBX Parts & Accessory Suppliers, Dealerships, Mechanics, OEM Parts, Speciality CBX Shops
- ↳ 4 Sale/Wanted -or- Links To Great Items 4 Sale
- ↳ Dan picks the best Videos, Pix, Want Ads, Technical and General Posts Each Week For Us. Amazing recaps.
