´79 steering stem with prolink front end
Posted: Wed Feb 27, 2008 6:07 am
by piit
Hi, I am updating ´79 model by prolink front end. The problem is that I do not have prolink steering stem, lock washer and stem nut. So my question is that can I use early model steering stem with prolink triples? In my opinion I can use it and then I can use early model upper bearing as well.
I have went thru the other discussion on this case, but still unclear to me.
Br, Petri
Posted: Wed Feb 27, 2008 8:05 am
How did you end up with Prolink triple tree brackets without the stem
I have never done it, but I think it is possible to press the early stem in the Prolink lower bracket and use it.
Posted: Wed Feb 27, 2008 10:18 am
by piit
I have collected prolink front end parts from different sources and once I got triples and forks with good money without steering stem.
I agree that should not be a problem to press out steering stem and press it back to prolink lower triple. Good to hear other opinion too, Thanks!
Posted: Wed Feb 27, 2008 11:20 am
by alimey4u2
piit here is a good thread on a similar conversion. Weather is getting better here so I should be in the garage soon.....
viewtopic.php?t=3256
Posted: Wed Feb 27, 2008 11:28 am
alimey4u2 wrote: Weather is getting better here so I should be in the garage soon.....
Lucky you
I had to dig myself out of a foot of snow this morning at 6:00 a.m.
Posted: Wed Feb 27, 2008 11:34 am
by alimey4u2
Sun is shining, birds are tweeting, Spring is in the air Mike....
Posted: Wed Feb 27, 2008 11:37 am
by cbxtacy
Posted: Wed Feb 27, 2008 1:40 pm
by piit
alimey4u2, jep I know that mail chain. There is discussed ´80 not ´79 front end update. Prolink front end is straight installation on ´80, but not with ´79, the upper steering bearing need to be changed.
Posted: Wed Feb 27, 2008 1:52 pm
by alimey4u2
piit wrote:alimey4u2, jep I know that mail chain. There is discussed ´80 not ´79 front end update. Prolink front end is straight installation on ´80, but not with ´79, the upper steering bearing need to be changed.
piit, sorry for that I should read more carefully.....
