Prolink Fork In Early Model Frame & Steering Damper
- cbxtacy
If you're really interested in keeping a stock appearance, I can send you a set of 82 CBX wheels in exchange for those inferior British wheels currently gracing your CBX.
YOU'RE THE ONE
YOU'RE THE ONE
- alimey4u2
- ICOA Web Video Director
- alimey4u2
- cbxtacy
- alimey4u2
OK, Parts for the damper installation...
"Lockhart/Phillips steering damper ( the longest stroke available.)
"Harris" fork connector.
1" thick, custom made bracket mounted to "Rotorwoman" alloy engine hangers. (Not sure what alloy she used for these but it's mighty tough.)
I'm sure anyone could weld or braze a bracket onto the stock hangers or frame to suit though....
Other bits like rod end couplings sourced either in Mcmaster Carr or Midwest Control Products. 12mm "Oilite" bearings ( bearingboys.uk )shrunk into the alloy bracket to form a gimble for the damper body. I may upgrade to ball bearings if wear rate proves necessary. "bearingboys" have suitable mini bearings that are inexpensive & will suit.
Function is excellent, hydraulic setting on low for town riding & being able to adjust to suit conditions.
Action ( rate) is also controlled by the connecting angle. This allows light damping at center & becomes more aggressive ( proportional) as you get off center.
No limit to steering lock both left & right ( just... )
- cbxtacy
- alimey4u2
Thanks Steve, I mounted it to the top of the hanger itself with 2 X 8 mm allen head bolts (recessed, hidden behind rubber bungs). There is a flat area on the "Rotorwoman" hangers to facilitate this. Position is critical not to hit the tank & limit lock which requires all of the damper length, save about 2 mm.steve murdoch icoa #5322 wrote:Great looking set-up, Larry!
Does the custom bracket mount to the hanger itself or does it use the stock frame holes and a longer bolt?
- cbxtacy
Larry, yours looks finished, mine looks crude. A few hours with my sawzall and a drill and I produced this pile of bracketry:
that does this:
and I'll probably do the same for my other X's.
The nice thing about mine is it clears fairings on pro links and big oil coolers.
that does this:
YOU'RE THE ONE
YOU'RE THE ONE
It doesn't appear that it has all that much travel, from full lock to full lock . . . . and it looks like the flimsy outboard bracket with it's single mounting bolt to the engine hanger would flex away most of the tiny amount of travel he does have in the critical 'straight down the road' mode - I can't see that dampener being very effective
The difference between that outboard bracket and yours is more than between night and day . . . . I think you correctly assumed that ANY flex there would negate most of the gain Larry
- alimey4u2
I do like Georges "idea", in Georges words, "bracketry a little crude". With a longer lever travel ( arc) at the headstock base bracket & more robust fittings I think it shows promise. From a purist point of view, I would "possibly" struggle with it shadowing the oil cooler but that may be avoided with modifications on the same theme.
No need for me to change but those with restrictive fairings, this "may" be the way to go, with revisions....
- cbxtacy
To answer all your questions about how it works
1. It uses the whole stroke of the damper side to side
2. the cooler is not in the airstream so placing a small obstruction in front of it does no real harm
3. It takes very little friction for a damper to be effective, even with the damper on the stiffest setting there is no flex in the bracket
It's ugly, effective, and simple to fabricate. I went to Home Depot and a couple hours later, the damper was working. I used to have it mounted similar to Larry's (you can still see the fork connector still on the forks) but it was too close to the tank and there was too much side to side movement.
YOU'RE THE ONE
YOU'RE THE ONE
