Hi
Can anybody please tell what is the correct torque value of the 12 exhaust nuts of the 79 Z.
I've looked in the manual and I've looked in the forum with no success.
Thanks in advance!
Aris
Exhaust nuts torque
- Kool_Biker
Exhaust nuts torque
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
Re: Exhaust nuts torque
Standard torque for 6mm bolt would apply: 8-10 Nm
- Don
- Amazing Poster
I wouldn't touch them with a torque wrench
You're compressing the exhaust gaskets when you tighten them - The correct amount is whatever it takes to seal the header pipe . . . . nothing more
Wiggle the header pipe as you snug them up and leave it there - If it leaks, loosen it a tad, wiggle it some more and tighten it just a little more than the first go around. Doing it this way will enable you to use and re-use your exhaust gaskets several times. I take my pipes off the bike several times per year . . . . sometimes just so I can do a thourough cleaning of the bike . . . . and the pipes. I've successfully re-used the same set of gaskets 5 or 6 times. When one fails to seal with a 'reasonable' amount of torque on the nuts, I flip the gasket over - If it still leaks, I replace that one gasket
I never have anywhere near the maximum torque on them for a 6 mm fastener
- Will
I don't know what the torque is, because I'm not that good a mechanic. But, whether you use a torque value or do it by the feel method (yup, that's tight), check it after bringing it up to full heat. Things tend to stretch with heat. In fact don't tell anybody, but I like to tighten them a second time while they are still hot.
Don wrote:I wouldn't touch them with a torque wrench
Don, if that was the case, Honda would have made a recommendation in the service manual as to the process.
You will not reach the 8-10Nm while crushing the gasket. Once you approach the seat, the torque increases. I find it very difficult to "feel" the proper point where to stop torquing and I have seen a few studs pulled out of the cylinder heads. that's why I stick with the torque wrench and 8-10Nm
With the flanges on my Kerkers, they are are almost bottomed out when they start to tighten.
ICOA #6266
1979 Honda CBX
2003 Honda Blackbird
2019 Honda CRF450L
2022 Honda Goldwing
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
- Kool_Biker
So it seems "feel" is the name of the game. I tried it, and seemed to work for me.
Today I started my bike, with the exhaust on, seemingly with good sealing on all 6 cylinders.
Thanks!
Thanks!
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
ICOA # 6309
Berkshire, Windsor
