Blinker Problem
Posted: Mon May 12, 2014 10:18 pm
by johnod
Tried my turn signals yesterday, while they come on as they are supposed to, they don't blink, just stay on.
Any idea what would cause that, and a fix?
Re: Blinker Problem
Posted: Tue May 13, 2014 1:46 am
The flasher unit under the right side cover is a likely suspect. Up high, to the left of the battery, in a rubber bootie. Replacements can be had at your FLAPS. Is the battery charged, and/or was the bike running?
Re: Blinker Problem
Posted: Tue May 13, 2014 9:11 am
by johnod
Ok I'll have a look, Yep batt charged, I don't think the bike was running tho.
Re: Blinker Problem
Posted: Tue May 13, 2014 10:55 am
by spencer
Some flashers, such as the original on my '79, will not flash when the voltage is a little low, such as when the engine is not running, or even if it is only idling. I replaced mine with a different stock one, and it worked fine. Later, when I switched to LED turn signals, I had to replace the flasher with a solid state one which will flash no matter what.
Re: Blinker Problem
Posted: Tue May 13, 2014 3:04 pm
by Mello
I have the same result as Spencer if the bike has not been run for a while. The indicator (blinker) sometimes doesn't flash even when the bike is at idle, just after start up. It's fine after she's run for a bit though.
Re: Blinker Problem
Posted: Sun May 18, 2014 8:19 pm
by johnod
Got it fixed, thanks
Re: Blinker Problem
Posted: Wed May 21, 2014 1:18 am
johnod wrote:Got it fixed, thanks
What was it? Close the loop for those that follow please
Re: Blinker Problem
Posted: Wed May 21, 2014 8:50 am
by johnod
Sure.
The problem was the PO ( present owner) is not tooo bright and despite labeling wires in the headlight when he removed it, he screwed up the reassembly.
The wiring diagram and an hour to figure it all out, and redo it solved the problem.
My advice is don't let that guy near your bike.
Re: Blinker Problem
Posted: Wed May 21, 2014 3:08 pm
by Rick Pope
So I'm not the only one to look in the mirror to find the problem?
Re: Blinker Problem
Posted: Thu May 22, 2014 1:13 am
I'd put you to sleep with similar stories from my projects. Glad you got it sorted.
Re: Blinker Problem
Posted: Thu May 22, 2014 8:30 am
by johnod
Rick Pope wrote:So I'm not the only one to look in the mirror to find the problem?
Have to remember this.
