All blinkers blinking togethher???
Posted: Sat Apr 19, 2014 3:16 pm
by jomi32
Hi, I have strange problem all my blinkers started blinking together when I set them left or right. I have checked bulbs, fuse, wires, plugins, ground contacts, I even started taking off the tape from wire harness. What could make this kind off failure?
Re: All blinkers blinking togethher???
Posted: Sat Apr 19, 2014 3:55 pm
My guess is the turn signal relay. That's the only place where all the inputs for the turn signals come together. Or your turn signal switch has an internal short. The Light Blue/White and the Orange/White wires coming from there should not have juice at the same time.
Posted: Sat Apr 19, 2014 5:12 pm
by tevan
My bet is the turn signal switch or somebody plugged them in together in the headlight. Did everything work OK before the way it was wired?
Posted: Sun Apr 20, 2014 5:51 am
by jomi32
Everything works fine last year and few kilometers when i left for gasoline station to get gasoline...
Posted: Sun Apr 20, 2014 10:15 am
by jomi32
Problem solved; it was ground problem, but hard to find out!
Posted: Sun Apr 20, 2014 12:21 pm
by tevan
Great... I will remember that. Which ground connection was it?
Posted: Sun Apr 20, 2014 4:23 pm
by jomi32
To the gauges & front blinkers.
Posted: Sun Apr 20, 2014 7:45 pm
by tevan
In the headlight bucket?
Posted: Mon Apr 21, 2014 7:03 am
by jomi32
tevan wrote:In the headlight bucket?
Yes...
