All blinkers blinking togethher???
- jomi32
Hi, I have strange problem all my blinkers started blinking together when I set them left or right. I have checked bulbs, fuse, wires, plugins, ground contacts, I even started taking off the tape from wire harness. What could make this kind off failure?
Live every day happy, even your life will be one day less! Said by: Major Larry A. Thorne
Same in Finnish: Ilosest ellää pittää vaik päivää vähemmän! Capt. Lauri Allan Törni from Finland
Re: All blinkers blinking togethher???
My guess is the turn signal relay. That's the only place where all the inputs for the turn signals come together. Or your turn signal switch has an internal short. The Light Blue/White and the Orange/White wires coming from there should not have juice at the same time.
My bet is the turn signal switch or somebody plugged them in together in the headlight. Did everything work OK before the way it was wired?
- jomi32
Everything works fine last year and few kilometers when i left for gasoline station to get gasoline...
- jomi32
Problem solved; it was ground problem, but hard to find out!
Great... I will remember that. Which ground connection was it?
- jomi32
To the gauges & front blinkers.
In the headlight bucket?
- jomi32
Yes...tevan wrote:In the headlight bucket?
