Choke Lever
jt
Choke Lever
Post by jt »
With the way the choke operates, Is it necessary to use the stock choke lever? I would like to try and use switches from a Euro CBR 600, that has the choke lever built into the switch housing?
JT In Texas
the mirror every mornin'.
Re: Choke Lever
JT: If the choke lever you want to use operates the cable properly, I see no reason why it shouldn't work. Just try and see how much "pull" you are getting 8) Make sure it pushes back alright also.
jt
Re: Choke Lever
Post by jt »
Ok, Thanks for the reply. When I give this a try I'll see how it operates the choke first before I get to involved with it.
Thank you.
JT
JT In Texas
