Converting Run/turn signals to Turn signals
Posted: Fri Apr 22, 2011 2:04 pm
by tanukusiva
Hi All,
I am in the process of converting my 1981 CBX into a naked bike, I say this as a process because what seems to be a simple task turned out to be a major process. I didnot want to mess around with the part of the wiring harness that was inside the faring so, I thought I would make my own, buy connectors, attach headlamp. Any ways in the process I bought some turnsignals that were 2 wire application but the CBX fronts were 3 wire. I tried all combinations with out any success. I would really appreciate, If anyone can enlighten me about how to complete the circuit to make those 2 wire turn signals work.
Siva
Re: Converting Run/turn signals to Turn signals
Posted: Fri Apr 22, 2011 2:23 pm
Siva, welcome to the site. If you don't post pictures of your project it didn't happen :-).
J.R. Luksik is your man, having done that conversion twice I believe, and also being an expert in all things moto-electrical. His handle here is CBX-tras. He may or may not catch your post, I'd ping him directly.
Posted: Fri Apr 22, 2011 3:02 pm
Try to find the Light Blue (right) and Orange (left) wires in your main harness and connect the signals to those.
Posted: Fri Apr 22, 2011 4:50 pm
by tanukusiva
I've been asked to post my pics of my "X" earlier but it is not pretty yet. I think with this last modfication it will be perfect.
I've tried that combination also. I've located LB/W and O/W being the running lights and LB and O being the signal lights, However when i turn on the switch the signal stays "ON" but doesn't blink. I am guessing that the circuit should complete for the flasher to activate because when i connect LB and O together the flasher activates with the turn switch.
Posted: Fri Apr 22, 2011 6:10 pm
If the signals come on but don't blink, you may have a bad flasher. Or your battery may be low - some flashers will barely work @12 volts. You seem to have them connected correctly, just make sure both front and rear on both sides are all connected when you are trying them.
Posted: Fri Apr 22, 2011 6:48 pm
Yes. If the rear is not connected or has a bad bulb, the front may not blink.
