Page 1 of 2
Stranded -- how do I, umm, make the wire hotter?
Posted: Tue Nov 04, 2008 1:22 am
by last426
Actually, I use my cbx everyday and it stranded me and is at the Bart station tonight. I turned on the key, hit the starter, and the oil light and headlight went out and all was dead. This is the second time this has happened this week. I wiggled the wires under the side cover and all turned on but as soon as I pressed the starter, all faded out. The first time I removed and lubed up the ignition switch but, obviously, that was not the issue. There has to be a bad connection or fried wire somewhere between the battery and ignition switch. Any ideas where to start? Also, can I just jump from the battery to, where, the fuse block by the ignition switch to limp home? Thanks, Kim.
last426@yahoo.com
Posted: Tue Nov 04, 2008 6:42 am
I always try the simplest solutions first. Try the battery connectons and battery itself.
The brains of the organization will along shortly.
Posted: Tue Nov 04, 2008 6:45 am
by Rick Pope
While we're waiting for the brains, try checking voltage across the battery, then hitting the starter button. I'm betting the voltage will drop to nothing, indicating an internal break in the battery.
But, I could be wrong....
Posted: Tue Nov 04, 2008 6:46 am
by alimey4u2
Guessing it is a poor connection somewhere under the sidecover. I doubt if it's a short else it will blow a fuse.... This is a fairly high res pic that will be fairly clear if you resize it larger....
Posted: Tue Nov 04, 2008 6:50 am
by alimey4u2
Rick & Steve make very good points.... 8)
Posted: Tue Nov 04, 2008 7:02 am
by alimey4u2
Also... check the "main fuse" connections under the right sidecover....
Posted: Tue Nov 04, 2008 7:35 am
I had exactly the same symptoms with a bad cell in the battery.
Posted: Tue Nov 04, 2008 3:05 pm
by last426
I hope it's not the battery -- I put in one of the expensive gel types about a year ago. I looked at the diagram and my next move it to check the main fuse and that connector -- if those are okay, then the issue is after the ignition switch (but that doesn't make sense to me). Thanks for the help. I will keep you posted. Kim
Posted: Tue Nov 04, 2008 3:17 pm
by Terry
steve murdoch icoa #5322 wrote:I always try the simplest solutions first. Try the battery connectons and battery itself.
Makes sense. Wiggling wires and all comes back on but when you hit the starter button, all goes off. Sounds loose to me. BTW, you didn't let that X sit in a BART parking lot all night did you?
Posted: Tue Nov 04, 2008 3:55 pm
last426 wrote:I hope it's not the battery -- I put in one of the expensive gel types about a year ago. . Kim
Are you sure, it is a Gel or is it an AGM? Actually, Westco had some problems with that particular size AGM. That was my bad one too.
They will replace it.
Posted: Tue Nov 04, 2008 6:27 pm
by last426
Yep, but it is outside every night, rain and all. I got this bike in 2000 when I lived in San Francisco. Moved to the east bay and use it every day to go to BART. Also a little casual riding but not like I used to. In all the time I have had it, I only have had three people notice that it was something different. I guess bay area folks are too hip for the room (or too detached to notice). So now I am in SF working and my truck and bike are both at BART. That's a pain. Kim
Posted: Tue Nov 04, 2008 6:37 pm
by Terry
Which station?
Posted: Tue Nov 04, 2008 11:47 pm
by last426
Rick Pope wrote:While we're waiting for the brains, try checking voltage across the battery, then hitting the starter button. I'm betting the voltage will drop to nothing, indicating an internal break in the battery.
Ding, ding, ding, ding. Finally had a chance to rescue it and it is the million dollar battery -- now if I can find the dumb receipt. Thanks for all the help guys, glad I got the bike home. To see what last426 is, go here http://www.marlia.com/charger/index.html Kim
Posted: Wed Nov 05, 2008 4:12 am
by alimey4u2
Good call guys..... :thumupp:
Posted: Wed Nov 05, 2008 6:44 am
by Rick Pope
even a blind squirrel finds a nut occasionally.
