Have had my '82 for 7 years or so. It came with an aftermarket horn. Recently the horn works only intermittently. When I press the switch I can hear some "contacting" in the horn unit and intermittently the horn does what a horn is supposed to do. Otherwise I just hear the contact noise. If I operate the switch too much the yellow button becomes heated to the point it is too hot to touch but not melting.
Any advice? Do you think the problem is in the horn or the switch? If the switch, what are alternatives as the manual says they "must be replaced as assemblies"
Thanks in advance for any input....
Horn / switch
Horn / switch
Brian L - Clearwater, FL USA
- cbxtacy
- CBXSUDBURY
Checking the switch is always a good idea, but if you do not have too much experience with taking that apart, I would recommend trying a different horn or cleaning the horn.
I too have aftermarket horns on my 82. That same symptom happened to me as well last year and I cleaned out the horn from the rust build up inside the horn or diaphram of the horn.
That solved my problem and has worked well since. That may not be your problem, but well worth looking at.
Yvon CBXSUDBURY
Yvon CBXSUDBURY
