Alternator R+R
Posted: Wed Aug 23, 2006 9:56 pm
Hi guy's,
I haven't posted anything for a while as it's been a very busy summer putting an addition on my daughter & son-in-laws house (I'm to old for this but i love it) and I finally got some time to work on my 81's alternator, and I expected the worst since it's had the dreaded ratchet sound for about 2 years now.
After taking things apart I was somewhat pleasantly surprised and somewhat cornfused in that the brushes at 23k only showed about 30% wear and the stator and brush rings looked new
. Surprised because the brushs in my 80 were shot at 12k, well only 1 of them actually, and the other thing on the 81 was that both brushs were worn exactly the same and I truly expected the results found on the 80. I guess you can never tell. I had bought all of the bearings and seals as well but the bearings were fantastic, smooth operation and free, why mess with success ? I also found that the clutch plates followed normal wear in that they were about .010-.020 convex with the inside edges blued, I do not believe that Honda ever made these flat ! After resurfacing them I put in a new spring which was about 1/8 in longer than the old one (highly recommended) and I also added a .015in shim behind the spring seat backup washer to make up for what I had to take off to get them flat.
As a result I didn't see any real difference from before to after but I also wasn't having any issues before so this was pure preventative and had I not had the ratchet noise would not have pulled it although the general consensus here has been that I was pushing the envelope on the normal brush life which by what I had seen would have actually been around 60-70 k before needing to be replaced, but after my 80's results who can know ? The clutch would have been toast long before the brushs, has any of you ever checked a new set of plates for flatness ? I'd just about bet they aren't so it may behoove (fancy word eh ?) you to check before installing.
Anyway I hope this may help some of you and at this point wish I'd have taken pictures then at least I could show off the highly polished pretty cover that I did before putting it all back together, probably good for another 10mph and at least 20hpwer, what do you think ?
Steve P.
Steve P.
