Looking for a CBX repair shop in San Jose, California
Posted: Wed Jan 11, 2006 11:52 am
by CDNCBX
I believe I 'toasted' something in the ignition system when I tried to jump start my '79. Headlight does not even come on with a good battery now - and starter will not work. I have checked the fuses (and I'm going to replace all of them this week as they look original).
Just wanted to start my search for a CBX mechanic in San Jose in case I need one. Any recommendations out there? Thanks in advance!
Re: Looking for a CBX repair shop in San Jose, California
Posted: Wed Jan 11, 2006 12:11 pm
by fasterspider
CDNCBX wrote:I believe I 'toasted' something in the ignition system when I tried to jump start my '79. Headlight does not even come on with a good battery now - and starter will not work. I have checked the fuses (and I'm going to replace all of them this week as they look original).
There is a blade fuse on the solenoid you need to replace.
I am willing to bet you that is your problem.
30 amp blade fuses are a dime a dozen at your Honda dealer.
The solenoid is under the side cover and it is semi easy to replace the fuse.
Posted: Wed Jan 11, 2006 1:49 pm
by Terry
If faster's suggestion doesn't cure the problem, contact Bruce at Milpitas Motorsports, 408 263-6060. He works on both my Xs and used to own one as well. Very good wrench.
CBX mechanic in San Jose, CA
Posted: Sun May 11, 2008 12:40 am
by CDNCBX
Honda of Milpitas seems to have shut down. Does anyone have contact information for 'Bruce', the mechanic there who used to work on the CBX's?
I need a CBX-savvy mechanic to diagnose and fix a starter issue (it seems to be jammed - and engaged with the engine).
Thanks in advance for any info.
Posted: Sun May 11, 2008 12:59 am
by Terry
He's now doing as needed work for Fremont Honda. Call the service manager and request Bruce to work on your X. Tell him hi for me.
http://www.fremonthondakawasaki.com/
There is also a small shop in Milpitas on the same street as Milpitas Honda was on, just a bit north. The owner has an 82 and does good work too. I forget his name now but its So. Bay Cycle at 408 263-2475.
