Took the CBX out this morning. An hour later stuck on the roadside with a blown main fuse. disconnected the Red/White, Green, Black connector (Red/White and Green go to the rectifier, Black goes to ignition) and got going again with spare main fuse.
At home I checked the alternator/Stator resistance: .5ohm vs manual spec of .4ohm and White to Black 35 ohm (no specs in manual);
All Yellows to Green and to Red/White at the rectifier 4 to 5 meg ohm in both directions (way out of spec -manual says 5-40ohm forward and 2 meg reverse);
Red/white to Green at rectifier .3ohm - almost a dead short; ohm's law says that draws 40 amps through a 20 amp fuse - no wonder!
Everything I read on rectifier/voltage regulator/alternator problems result in a benign failure. Mine is catastrophic.
I am charging up the battery before I can check the voltage regulator.
Any ideas??
Thanks in advance,
Ray Forsyth
Dead Short - Seems to be in the Rectifier
