help ,part found in stator housing
Hi ,I'm freshening up the look of my 79 .So i removed all the covers that I could to paint . When I took off the covers A and B over the stator/rotor I noticed a little round part that was just laying on the floor of my garage . It fits perfectly in the hole at the top of the cavity in the stator housing . any suggestions ? Thanks
- shiskowd
Re: help ,part found in stator housing
I believe that is the oil metering orifice that sits in the end of the primary shaft that the driven clutch plate is attached. It is simply a press fit that you should be able re-insert. Controls the oil volume flowing into the clutch plates.
Yes, that is correct. Tap it back in with a brass drift, after making sure the metering hole is clear and the interior of the primary shaft is clean.
- herdygerdy
Ouch. I feel your pain Dave. Is the hole in the crankcase oil gallery repairable? And that orifice in the end of the primary shaft looks gummed up solid too.
So just to be clear,that little round piece just goes back in that hole ? You talk about clutch shaft and oil volume ,also I found no oil in the stator housing. Just asking because I don't know . Thanks alot .
Yes, in the end of the primary shaft. All oil sprayed into the alternator clutch cavity immediately drains through that large hole in the bottom directly to the sump. Good thing too, as a rather large amount of clutch debris gets carried to the sump. That is why it's important to remove the sump cover and check and clean it every so often.
Well, I'm going to give that hole the old JB weld treatment and see. I have the engine tilted now, so have good access to the outside and inside of the hole. There's no pressure there. Maybe make it a second crankcase vent?
Yes, the metering orifice is plugged solid. Have seen this before. The clutch and advancer shaft have to come out to reach through the primary shaft and tap the metering plug out for cleaning, but more importantly, to clean out the oil galley in the shaft. I've seen these full of goo. I've also seen this lack of oil flow take out the primary shaft bearing on that side. Hope that's not the case here, or this will get very expensive (for the customer, not me!).
All this comes from the clutches slipping so much they and the end of the primary shaft get very hot.
I'm still a bit confused . Do I push the orifice all the way down the shaft till it bottoms out ? O rdo I leave it near the end ? Also what was the pic of the spring about . Am I missing one of those now ? Thanks for the help .
The aluminum button is tapered, and will seat itself just inside of the outer lip of the shaft. The spring I show is THE alternator clutch spring. It should be behind the drive plate you show in your picture, along with at least two shim washers (a very thick on and a thinner one). And a spring seat next to the case. You had to have one when you took it apart. Stock height is 31mm. 29-31mm is a good working height. The one in my pic is only 23mm. Excessive heat sacked it. But if you are missing the spring, then you have lots more problems to address.
By the looks of your clutch, you probably should hand lap them a bit smoother and see what you have.
Oh, the hole you tried to plug is the crankcase vent. Don't plug it!
Thanks for the imput ,it makes sense now .
