Guage wiring diagram
oldbikerdude
Post by oldbikerdude »
I have the 82 Pro-Link, and the bike does have the clock and the temperature gauges.
It looks like someone messed with the wiring on the gauges,
It appears I have only partial wiring complete.
Was reading another post on "Optional gauges" by member "cross", and member "kp94" replied by adding a pic of the built in wiring harness which the 82 should have.
Here's that pic.
So my wiring harness does have the upper harness portion, as in the 2 dual female bullet connector terminals and the single red bullet terminal, although none were being used on my bike.
I also have only the white 4 pin connector on the other end, only 2 of the 4 wires were attached, and no idea where the wires go.
And I am totally missing the black connector, which I think should come out of the small fuse block on RH pocket.
So my question, does anyone have any details on the correct hookup, pics, instructions, wiring diagrams on what I need to get back to proper wiring.
Thanks in advance,
